jmp
Spent sunday investigating internal slapping in the mast to find a 3 core wire to masthead not in the conduit presumably for the purpose.I want to renew the VHF,tricolour ,steaming/deck,and fit a NASA wind system,all in the conduit.The NASA has a plug on the continuous wire which would appear to be unremoveable and will not fit in the conduit ,which has prominent rivet heads inside at intervals where fitted to the mast.I also think thee existing wires like immersion heater type cable are too bulky . What size wire is needed for the 4, 20w bulbs (may be able to reduce to 10w, if wire is much less bulky).
Is there a multi core wire with say 2 heavy cores for -v.This would be more likely to go in the conduit .
Has anyone joined a NASA wind cable .I see great inconvenience when removing the mast if all wire to the repeater has to come out, as well as the plug problem in the mast!
<hr width=100% size=1>jmp<P ID="edit"><FONT SIZE=-1>Edited by jmp on 31/03/2003 09:30 (server time).</FONT></P>
