richardbrennan
You might recall I was asking for assistance to cure a mast panting problem on my Westerly Ocean 33. I will not bore you with the whole saga, but I found out from XW Rigging that Westerly/Selden unusually specified tensions for both the cap and lower shrouds for this particular rig and so had the rig set up accordingly. These tensions are high and have resulted in the stainless steel mast support post taking on a curve of its own which is clearly not a good thing! This too is a known problem on some of the earlier boats and later models had a beefed up post of noticeably thicker diameter.
I clearly need to replace the post with a beefed up version and know from another later O-33 that the outside diameter is nine centimeters. What I don't know is how thick the wall is as there are flat plates welded on top and bottom, the top one taking the bolts from the mast step through the deck and the bottom one resting on a heavily reinforced area of the hull. From what I can see on line, 2 mm seems to be a pretty standard wall thickness, does anybody know if thicker stainless tube is available and from where? I also need to know who might make up such a support in the Portsmouth/Gosport area, Madge Marine has been suggested?
