William_H
I would suggest your headsail is cut too high. The sailplan in the drawings has a much lower foot and clew. You're losing a load of power ahead of the mast.
Get another headsail (borrow one?) and see if that changes your balance, (neutral or lee helm). Then you may have the room to manoeuvre in mast rake without making matters worse.
+1 The jib is often raised to fit in the drum turnscrew etc on the forestay and under the jib tack. Ideally you want the drum for reefing right down as low as possible. You may be able to do without a turnscrew in the forestay. Even better is a drum under the deck level. probably too hard to manage.
A jib does work better if it is closer to the deck.
Also note however that as said weather helm increases with boat heel no a mount of sail ballance can overcome that. good luck olewill
