jpeach
New Member
Hi Folks,
I'm contemplating doing a mast replacement on my 28ft ketch. It's a custom built boat from the 80s, so this would be just another modification!
Currently it has a main mast of about 9m from Proctor, which has seen better days - lots of surface corrosion and holes from old fittings. I've come in to posession of a nearly new Zspars mast at the yard I'm in from someone converting a motorsailor to a motor boat. In most ways it could be adapted to fit the size and geometry of the existing mast + spreaders + standing rigging. Its about 1ft too long currently so i've got some scope to cut it down
I'm contemplating the mast foot arrangement though. And with the change giving myself the possibility of raising and lowering the mast myself.
The current mast is deck stepped, and the new one would be too, and there's two options
1 - get and fit a new mast foot from z spars
2- build a more robust tabernacle with a pivot point maybe 1ft from the coachroof/mast base
In an ideal world i'd be keen to go for the latter, but struggling to understand
1) how the mast base would make contact with the base of the tabernacle/coachroof when raised to transfer compression loads and still be able to pivot - would an angle need to be built into the tabernacle/cut into the heel of the mast? or some sort of wedge?
2) how to approach getting the tabernacle tight enough to the mast sides to prevent lateral movement when the mast is raised but still free to swing.
Any input or advice on the above would be greatly appreciated!
Alternatively, do folk have any experience of self-raising a mast of this side with a more conventional foot - by using a gin pole or a frame? Most things online seem to apply to smaller spars
For reference this is a smaller version of the type of zspars mast foot i'm talking about https://forums.sailboatowners.com/attachments/1718493888313-gif.225442/ (can't find a photo of the right one easily)
