mast climbing
tyse
9 Jul 2003
barrow cumbria
hi,
the mast head fitting for my topping lift has just fallen to pieces so i need to fit a new one, i was wondering if a mast of a 22ft boat is built to support some one climbing up it ( im a big lad 14.5 stone all muscle honest), or will it be easier and safer dropping the mast
Avocet
3 Jun 2001
Cumbria
I asked the same question a few months ago and the concensus seemed to be that the compression loads on the mast from the rig would be much larger than the weight of a person. I'm a sylph-like 16 stone and our boat is a 27 footer (mast about 30' tall). Try a forum search.
That said, I'm still not convinced that it would be OK! In your case, I'd definitely unstep the mast. Is the boat afloat? If so, you might be able to partially lower it against a tall harbour wall. I fitted a roller reefing system that way and it was surprisingly easy!
snowleopard
Oxford
i was considering the same question with a 23 footer. i did the calculations which said it would capsize once i got above the spreaders.
Strathglass
Fife
We have sent the youngest crew (11stone) to the masthead on an Eboat (22ft with 660lbs keel) on a mooring in (flat water). We could only heel her to about 30 degrees, even with two crew on the sidedeck.
We would have liked more as the objective was to scrub the bottom before a race.
I dont think there would be any problem climbing to the masthead on a more conventionally ballasted craft 22ft or over long, as long as basic safety precautions were taken.
Regards
Iain
TimLamb
30 Sep 2001
Northumberland UK
I had to go up the mast recently (for the first time), I have a bosun's chair, but in the end just took the extendable ladders up to the marina on a roof-rack and used them, with two helpers holding the base and with them lashed to the mast, got the job done without any fuss, very easy, if you have access to a set of ladders ?
Good luck.
Tim
