Twister_Ken
Last few inches of my masthead light cable is in a sorry state (where it emerges from the base of the mast and goes through a deck gland to connect up below. Even some bare wire. So I need to repair/replace. Never taken a cable out of the mast (mast will be down, which is why I was jiggering about with the cable in the first place). Presume, if I'm replacing, I can use the old cable as a pull-through. How practical/sensible though would it to go back up the old cable to sound wire, and splice a couple of feet of new cable in using connectors and heat sealing the whole issue, then pulling the joint into the mast? It'll be below any halyards, etc.
And if replacing, what sort of cable to use? As I recall, currently three strand (tricolour in, anchor light in, common out) 12V, 25W bulb.
