vas
morning all,
got a few things to report on the main rebuilt thread as well as the fins one, however on the first week on the water after the fins where fitted I had to use them as static ones since geny was dead due to some silly short that took the control panel with it.
Took me two days to figure out a solution so eventually I can now turn the gen on using a barrel with key from one of the two Detroits previously fitted on MiToS currently tie-wrapped on a conduit just under the aft deck so you have to open the hatch, bend over, fish for the barrel and turn the key (very, very professional!)
But messing about with all that I run out of time for sorting out the fins control system. More on that next week on my next outing to the Sporades.
So now, I do vaguely remember someone (IIRC Portofino?) posting some links on MASE stuff and I did keep the links, and someone else (or was it again PF, or was it Bart on another discussion on remotely operating the generator from the f/b?) that mentioned alternative control panels to run a generator?
The original one as seen on p5 on this PDF: http://www.masenorthamerica.com/manuals/old-literature/IPB/IPB IS 07.0-11.5.pdf
apart from the ON, START, STOP touch buttons (and respective leds), has a few indicator leds that I find useful plus the feature to kill the gen if something's wrong (did it once that I had a problem with the impeller and no water was going through). Talking about overheat, oil pressure, AC output (ok, find that silly tbh...) and possibly one more.
So instead of spending time to figure out the signals from the oil press and temp sensors and building a new panel myself, is there any cheap and cheerful solution to my problem?
cheers
V.
cheers
V.
