Simon054
Hello,
I have a Yanmar 2GM20 engine fitted with a Martec freshwater system with an electric circulating pump and a calorifier. At around 4/4.5 knots (2000 revs) the system works well and the water temperature does not set off the alarm however above 5 knots (2300 revs +) and the water temperature slowly creeps higher and has triggered the alarm. The sea water pump is new with a new impeller and I have replaced all of the hoses due to their age and some minor leaks. If I fit another circulating pump with a higher flow rate across the calorifier will this keep the water temperature down at higher revs or should I fit a small radiator in the system similar to an oil cooler radiator across the air intake hose? Or has anyone solved the issue another way other than buying a new boat!!
