pauls_SPT
...or should that be marinating...not sure, anyway, how practical is it to convert a car engine to go into a boat? The GMC lump in my boat went bang in no small way a couple of weeks ago and, assuming every internal part of it is broken, I'll be looking for a new engine.
The problem is, 3 litre GMC engines are nigh on impossible to find, so I'm looking around for alternatives and one fairly obvious swap would be for a Ford V6 (Essex or Cologne), as they knock out about the same power, are about the same size and weigh about the same, too...they're also relatively cheap (under 500.00, at any rate).
How would I start with converting it to life at sea, though? The old GMC unit is pretty standard except for the inlet/exhaust manifolds, but can I get those for other engines?
Any help/advice/cautionary tales will be much appreciated,
Thanks,
Paul
Thanks,
Paul
