dustywings
I have a Mariner 3.5hp four stroke outboard on my tender which has been a great engine for years and has had relatively little use. Towards the end of last season it developed a cough when opening her up and would eventually die but always restart. It will run out of gear perfectly when I flush it out after use in a tank of water, the problem only occurs under load. My initial thought was fuel so I changed the fuel, cleaned the tank, checked the lines and shut off valve (there is no filter) and blew the carb through with an air line but to no avail. On talking to my local dealer they suggested it would be the carb so I pulled it apart entirely, soaked it in carb cleaner, blew everything through and reassembled but still no change. Having convinced myself that it was not the fuel I have bitten the bullet and fitted a new igniter (which wasn’t cheap!) but as you have probably guessed still no change. I am totally stumped, has anyone had a similar experience and might be able to shed some light on where to direct my efforts?
Thanks in anticipation!
