slawosz
Hi,
today my dinghy Mariner 2hp after 2-3 minutes of running started to get lower revs slower and slower (for like 1 minute), and then died. After 5 or 10 minutes I was able to start it again. Metal handle on the back was very hot, so I suppose it has issue with overheating, additionaly, telltale is not pumping any water. Also it has some strange smell, but hard to say exactly what it could be.
I found 2 guides how to disassamble the engine:
http://inadee.co.uk/marineroutboard.htm
https://www.troppo.co.uk/odds/Mariner 2M Impeller replacement.pdf
Engine looks quite easy to service alone, should I get this replacement kit?
https://www.ebay.co.uk/itm/Water-pu...528151?hash=item340d8b3c57:g:MFcAAOSweUNbHtY0
Or impeller only would be enough?
Also, there are 3 small holes, above propeller, on the leg, those were bit blocked, but not sure if it is water intake. I might hit bottom (mud and gravel) with engine, maybe its just blocked?
