coopec
N/A
I am trying to work out how I will plumb up my toilet/macerator pump/holding tank.
There two systems which seem to be popular but work entirely differently.
Boat Projects
Ericson Yachts
With the Boat Projects system as soon as you've used the toilet you'd press the button to start the macerator pump for a second or so to pump it into the waste tank. Then you'd empty the tank using a diaphragm pump at sea.
Ericson yachts uses the toilet pump to send it to the waste tank or directly out through the skin fitting.
Is anyone aware of the pros and cons of both systems and could express an opinions as to which is best?
Thank you.
Clive
Thank you.
Clive
