Bilgediver
thanks for the replies folks.
I have had HF scheds from Falmouth, Horta, Ponta Delgada and one or two other marinas ... however, as I cast my mind back ... always been at the end of the marina with clear sea to one side. Perhaps that'll make a difference?
At present, surrounded. A practical Faraday cage?
D
Don t you think it is a little irresponsible firing up your HF in a crowded marina. That is apart from the fact it is against the rules of most foreign and UK harbours.
How would you like it if a neighbouring yacht fired up his HF and then pushed it to max power as no one could hear him....Resulting in zapping and wrecking the front end of your receiver and or other on board electronics. It can happen.
You would be surprised no doubt at the RF burn that can be received when handling an antenna in the vicinity of another transmitting station. It shocked and burnt me. Just handling a length of flex for my short wave receiver. Luckily it was disconnected from the radio. Couldn t think what had happened initially. Mind you it was 1 KW RF transmitted from 50 feet away.
