Binman
I understand the CCA batteries give you a cranking power from 0 degree, where as the MF battery gives it from 32 degrees, are they both as good as I another, my battery needs replacing it is a 105 hr cca860 12v
I seem to remember you have an outboard engine so CCA is irrelevant for you - only important if you are using it as an a engine start battery for a diesel. Equally as you have no high charging or high consumption it is the capacity you look at and any battery that will fit the space will do. The larger the better as it will extend the time between charges.
I think you will find that the rating at 32F is often called MCA ( Marine cranking amps)
I have not come across MF before.
No such thing as a marine battery.
You won't need this pointing out, Vic, but others might: even if a battery has an 'MCA' rating, that doesn't make it a marine battery..
Mine is a marine battery !
700MCA and even got a picture of a yot on it!![]()
CCA for engine start deep cycle battery, such as Trojan, often 6v wired in series, for house battery.
Aren't "engine start" and "deep cycle" contradictions in terms?
Richard
Yes, but you have to allow for KE's lack of punctuation. I think that's what he meant.
