superheat6k
Just seen this, but my choice here would again be Loctite 577. It seals hot fridge systems at 30 bar, so will definitely work at 0.05 bar a few inches below water level at ~ 15 - 30 oC. Goes on in seconds and sets semi hard. Loctite sell it as a thread sealant but it works as well on re-sealing tired o rings and gaskets. However, if your leak is around the skin fitting itself then a decent face seal will be needed. 291 but will need a period to set. Butyl tape would sort this.Hi all - give the relevance I’m trying this rather than new thread…
We launched on Tues and one (of 6) new Tru Design through-hulls is weeping between the ball valve and the skin fitting. It’s to the tune of about a pint an hour. It was sealed with Loctite 5331.
Seeing as we’re very much hoping to re-seal either with a bung in the skin fitting or during a quick ‘racing lift’ (41’ AWB so can’t dry out!), what sealant is most likely to cure for service in an hour or two?
Are we stuck with PTFE - or might Sika, PU40, OB1 etc. not mind the re-immersion? (I otherwise have stock of and trust all three!)
TIA
