NormanS
I love having a calorifier. Not only does it give the convenience of hot water on tap, by making use of waste heat, when you have it, it is also something for nothing.
I'd definitely opt for a calorifer as the best upgrade from a 'primitive boat'. ... It start to look like the full system is standard for good reason?
I think the expanding hot water spitting out of the tap could be an issue with an 'open' system. As soon as you put a tap on the output, you need a relief valve and probably an expansion vessel.I agree with all that in principle and find a ‘full system’ just great. But from the OP it seems that JD has decided that a ‘minimalist’ HW system would meet his needs. If so, we’re now perhaps opening a discussion he’s already had with himself rather than addressing his specific technical point. For our boats and needs a ‘full system’ is the right choice, but JD wants something between that and a kettle. Are we really saying that that is never a sensible option?
Given that I am in the middle of having a nice new Nanni engine fitted, which could heat some water for me, but that I have absolutely no intention of fitting a pressurised water system, is there any reason why I could not fit an unpressurised one ... pipe from water tank to calorifier, pipe from calorifier to pump at the sink?
The OP has said that he does not want a pressurised water system. In that case any expansion of hot water in the calorifier will simply travel back to the main tank. Venting of the calorifier is only going to be a problem with a pressurised system.
Hot water going back to the tank is best avoided for health reasons. Better, as VivS has suggested, to fit a non-return valve, and let the expansion dribble out at the sink
Boiling a kettle takes no time at all. I would not bother with the calorifier or hot water tank on a small boat. The store of hot water gets used up very quickly and it is a breading ground for stuff unless kept very hot.
I presume you would need a thermostatic mixing valve on the calorifier, and that that would still work satisfactorily in the 'suck' configuration?
The only other snag I can see is that every time the calorifier heats up and the water in it expands the excess volume of water will dribble from the pump into the sink.
Many thanks, folks, for all these useful comments. To address a few in turn ...
I was just thinking of a hot tap. How hot do calorifiers get? ...
I'm quite happy boiling kettles, but if I can arrange for a supply of "free" hot water are fairly low installation costs, I'm tempted. For a start, it could be nice to use a pressure/gravity portable shower system. There is no scope at all for a shower in the boat.
Yes, thanks. I definitely don't want a full pressure system, for a variety of reasons.
Excellent point. I'll have to give some though to that.
It can get as hot as the normal engine operating temperature. I assume your engine will be indirectly cooled so 75-80C perhaps more. The owner's manual may give the thermostat operating range.
I don’t know as I’ve got a thermostatic mixer would be my quick answer!But I suspect hotter than I might like to have especially if children might use it, for example – see also lw395’s comments at #25 and #31.
But another question in my mind was how well simple manual or foot taps would cope with very hot water. Before I switched to a pumped system I had simple hand pumps and the galley one, which got most use, required new seals fairly often with just cold water. Even if you were happy on any safety issue, I would give that some consideration.
But perhaps others with experience of the simple system you propose know those are not problems?
If the system was piped so that the foot pump was pumping cold water into the calorifier, and the outlet to the sink was just a simple spout, no seals, valves or pumps would be exposed to the admittedly very hot water. ...
... Like many others, I'm sure, I don't have an automatic mixer valve, but with care, the high temperature is manageable.
