Alexis
I may be considered maniac, but I'd really want to keep things as simple as possible. Beeing hard deaded, I'm still trying to find a pumpless (theoretical at least) solution.
What would you think of the following system:
- Solar panel at say deck level (installed at an angle of course) with "hot" pipe going up a couple of feet and forming a loop (cabin top, along mast or pushpit) with, close to the panel, a one way valve. After this high point, the pipe would go underdeck to top of calorifier, then come back to bottom of solar panel. The idea is that the water going up the first part of pipe, just after the valve, would be slightly warmer than the water after the loop, as it will have lost some heat.
Is there any "theoretical" chance this wood work or am I just a dreamer ?
Alexis
Alexis
