MarcJ
I should be getting my grubby hands on a second hand solar panel from work in the next few weeks. Probably a 120W one. I'll be fitting it to ease the reliance on marina power and it's an obvious answer to keeping the batteries topped up when on it's mooring (lake at the moment, but probably sea next year) when we're away from it for weeks at a time.
It's a 20ft Vivacity and a 12V 160ah bank of 2 x 6V batteries.
I looked up several threads last night, looking into regulators etc, but really I was wondering how you best use, safely, the excess power created.
From what I've read I could easily get a couple of small computer fans to run full time to keep air circulating, we haven't got a bilge pump but that sounds like it might be an idea (though I'd prefer to plug the leaks better!).
Is there a safe way of creating heat to keep the cabin nice and dry, whilst not risking an electrical fire?
The other question is a simple way of getting whatever heat source to only run when the batteries are fully charged. I've learned from previous posts that some regulators have an output for "the load" which you can set to turn on at a set voltage - say 13.7V, is this right?
One solution I thought might work is a timer switch (a cheap 240V one) plugged into an inverter to come on a couple of hours a day over winter. Only left for say a max of 4 weeks.
Any ideas or experiences gratefully received!!
