wipe_out
Hi,
I like to use the boat in the winter so I don't want the hassle of properly "winterising" the engine after each use because it's a hassle.. So I want to make a "quick flush" system that I can use to pump some antifreeze around the raw water cooled engine after use.. We are dry stacked in the winter so this is relatively easy in terms of access..
Idea at this stage is to get a long narrow and fairly shallow plastic box that can go under the outdrive from the transom to the prop to catch the circulating antifreeze.. This will be pumped back into the earmuffs to recirculate until I am happy it's completely circulated..
So the process would be a fresh water flush from the hose to clear the salt and get the engine to temperature.. Then place the box and put about 10l of antifreeze into it.. Connect the pump to the earmuffs and run the engine again to circulate the antifreeze.. Once done collect up the antifreeze for the next use (I know it will be a little diluted but still means I can get a fair number of uses out of it before it needs replacing)..
Has anyone tried anything like this?
Probably the main thing I am not sure about is which pump is best suited to the job.. A bilge pump would give high volume of water at low pressure which might be ok since the raw water pump on the engine would assist in pumping the water around.. Alternatively an in-line pump would deliver higher pressure at al lower flow rate.. The in-line pumps seem to have a short duty cycle though of about 10-15 min which should be enough but I would prefer to be able to run it as long as I like..
Any thoughts of the pump selection?
