Iain C
That's the stock.
Hmm. Except I believe mjcoon, above, was thinking of the cylindrical steel 'spline' which goes vertically through many rudder blades, and may well need increased lateral profile to grip the inside of the blade when it's deflecting water flow. My rudder, as on most dinghies with swinging/lifting blades, doesn't have that.
From Wikipedia:
Spline (mechanical), a mating feature for rotating elements
Spline (mathematics), a mathematical function used for interpolation or smoothing
I think that I now remember the wooden slab stock on my Enterprise dinghy which was transom hung on pintles with a swinging blade.
Mike.
Spline is also a long thin bendy stick. The mathematical spline is a numerical version of the drawing office spline used to fit curves around points.
I don't think ply is the right thing to use...I think I would be happier with either solid hardwood, laminated hardwood, softwood sheathed in glass/epoxy or some sort of glass/carbon/foam.
I'm wary of using a more complicated construction process than my ability is equal to. So I thought just wood, as being tolerably easy to sand/plane. I hadn't realised that ply wouldn't be ideal; certainly I won't want any warping. I don't mind shelling out for a quality piece of hardwood, then committing half the winter to perfecting the aerofoil shape...but which wood is best?
The present rudder is over 2kg weight...I'd prefer that a replacement wasn't much heavier. I guess strength matters more though. Any idea what a teak 32mm plank, 4' x 1' will cost?
...your lazy jacks...
Don't use teak. Use a Western Red Cedar as per my previous post or for that matter foam.
Your what now?! This is a dinghy is it not?!!
Dan
But in all seriousness, the difference in weight between a carbon foam rudder and a plank will be less than the water soaked into the old girl's hull, your lazy jacks and rowlocks. Priorities sir, priorities. I'd also say that unless your existing rudder is structurally failing...why bother? You mentioned chunks are falling off it...why not just give it a very aggressive belt sanding, re sheathe it and fair it?
You will be surprised at the cost of materials to make a new rudder, and the skill required too. I would not even consider making a rudder for a boat like an osprey unless I really knew what I was doing and I vac bagged it.
I tend to think I'd either want to do a really god job out of carbon, or for a non-racing boat modify something secondhand.
You have actually done this?! As they say on the internets, pics or it didn't happen.![]()
Teak would not be good for this: thick sections of it tend to distort horribly in damp conditions. My wee hunter came with solid teak washboards, both of which were horribly bowed. Marine ply is ideal for a rudder.
