lesweeks
I’ve ‘inherited’ a couple of 1¼” Iroko lab bench tops which I’m going to use to make the cockpit lockers. My question is what adhesive to use for the tops/seats. My plan is to put an end clamp on each side with double tenons, wedged, in the middle so that any expansion will be equally spread across the board and so that the clamp cannot fall off. For much of the work on my restoration project I’ve used epoxy, but will this be too hard for this task? Should I go for something with a bit more ‘give’ to accommodate a bit of movement? Or, will whatever adhesive I use break down in time? Does anyone have any suggestions?
