Greenheart
I've buzzed around a few times with the Tohatsu 3.5 two-stroke on the back of the Avon Redcrest. It's a lightweight engine at around 13kg, but may be a bit more than Avon recommended, because the stern squats rather dramatically, and I began to imagine at the weekend that such an old inflatable might burst a seam under the stress.
The obvious thing (to me) is to find a way to mount the engine on the back of the Osprey, for the amusement and versatility it would add.
Trouble is, the Osprey's stern is mostly thin glassfibre panels that don't bear weight and were never meant to carry an engine. The deck flexes under hand pressure, and the transom feels very light.
The only strong points are those 3" protruding, outermost solid wood gunwales, encapsulated in glassfibre. So here's my first idea...
...I'll get a sheet of stainless, probably 2mm thick, and about 120cm (4ft) by 25cm (ten inches). The steel will be flexible enough to follow the curve of the afterdeck between the gunwales, so I can use heavy 10mm bolts to secure the sheet through the gunwales, making a stiff surface to the deck...
...then (before bolting the sheet down) I can drill holes through the steel and use countersunk 8mm bolts to attach a hardwood or ply bracket, to the steel sheet. I'm thinking that the steel will be a big enough area to spread the load of the engine (both its weight and thrust) over enough area of the thin GRP deck, that it won't harm it.
I realise the sheet of stainless will weigh nearly 5kg, plus the wood bracket, but I can't see how else to attach the motor. Plus, I really don't want to prevent the dinghy's rudder working as usual - so sheet steel seems smart because it's very stiff, but won't raise the level of the deck where the bracket needs attaching.
I await your criticism.
