Stevie_T
CharlesM
There is absolutely nothing wrong with making your own safety lines, as already said 'Don't be put off by doom mongers'.
Of course if you are going to do it it should be done correctly, and as you yourself point out if one breaks and somebody else dies, then you may indeed be liable.
However that aside, I work as a Rope Access technician and myself and thousands of others all work with home made safety lines, as approved by British Standard Code of Practice for Rope Access.
Here are some very important points to bear in mind though:-
Climbing tape is definitely not a good product to use, climbers use them for belaying etc and they are not subjected to shock loading. They are in fact low stretch and though are capable of withstanding a static load of 22Kn (2.2 tonnes) they will break quite easily if subjected to a shock loading.
Personally for sailing I use a commercialyy made sailing lifeline though I have yet to look into the suitability of them for a shock loading situation (which is likely to be what you get if you fall overboard in heavy weather) I suspect that they are low stretch and therefore in my opinion unsuitable. I would be interested to see any specification or testing for shock loading on sailing lifelines.
What we use is dynamic rope (climbing rope) of (say) 11 or 12 mm you can attach it direct to your harness and to a carabiner or similar on the other end thus saving one carabiner. A barrel knot is probably best to attach it to the carabiner as it locks it in place so the carabiner is always in the right attitude. A carabiner is not really the best item for sailing though if you do use one you should use a screw gate or better as a non screw gate can twist off if you are not careful.
As said already, do not use a bowline, they can come undone, use either a barrell knot as I already rcommended or a double figure of eight.
It is quite easy with rope to make one long enough to have two lines so that you dont have to disconnect to pass any obstructions etc.
