Mainsheet traveller on X-332
Upnorth
29 Aug 2005
Durham & Port Grimaud
I have a mainsheet traveller fitted to my X-332 made by Fredriksen (now Ronstan I think). The car, which is fitted with a recirculating balls, has started to run very roughly
As the ends of the traveller are inside the cockpit it is not possible to slide the car off the track to inspect the balls. There is an ‘end cap’ on the car which looks likely to allow the balls to come out, but I am a little cautious about removing it unlesss I can’t get it back together again. I have given it a good clean, and following most of the advice on various sites, not applied any lubricant. Lubricant apparantly causes the balls to skid rather than rotate.
I wonder whether anyone has any experience with this item. I am thinking that maybe the balls need replacing. . I think the current part is RC12223, fitted with torlon balls.
dt4134
9 Apr 2007
We'd use copious amounts of MacLube on a regular basis. I've never heard anyone advise against it before and I've raced with quite a few who should know.
As you're considering replacing the balls anyway you could give it a go. It isn't cheap but it's a lot cheaper than your traveller.
micha571
29 Sep 2010
www.teamswashbuckler.com
We have the same car on our x-99.
When it moved a bit rough last year, I applied lots of Teflon spray. That was successful, it glides perfect since. If any balls should really be broken, i'm sure you can get them out by removing the end caps.
pvb
UK East Coast
It looks like an RC12223, as you said, so should have 110 Torlon balls, 6.35mm diameter. If you remove the end cap, it ought to be possible to replace the balls with the car in situ, although I'm sure it would be a fiddly job!
Quandary
20 Mar 2008
Argyll
Harken cars come with a blue moulded plastic tray device the size of the car that you use to catch the balls and remove or replace them. Every Harken equipped boat will have about three or more of them, I have no idea whether they can be used for Ronstan cars though; I suspect the balls are a different size.
Monique
1 Feb 2010
Baleares
Mine was clogged with salt; lots of high pressure water and presto.
No more problem.
Spray furniture polish also works.
saltylegs
23 Jan 2010
Strangford Northern Ireland
I have one that used to be a spinny pole track fitting that I now use as an adjustable goose neck fitting. When moving it about I had a short piece of track that I could slide it on to from the track but in your case this would mean unbolting the track.
It is much easier to reload the new balls into the car if it is on a small piece of track so as you can turn it upside down etc. I think from memory you may get a plastic track profile when you are ordering the balls to aid this process.
unfortunately in your case I think that if you take a close look at the photos of your track you will see that the hard bearing surface has been worn away and you now have the rough/soft alloy showing, this has likely caused the balls to roughten and start to breakdown.
If you want a long lasting repair you will need to replace the track and the balls.
dt4134
9 Apr 2007
McLube is scandalously priced. Ask in a bicycle shop for dry lube. Essentially the same thing, without marine pricing.
Agreed. I tend to use auto factors (proper back street/industrial estate ones rather than the poncey ones on the High St) but I just wanted to keep to the basics in my previous post and MacLube was easier to explain.
William_H
28 Jul 2003
West Australia
Traveller
It does seem to me that one of the biggest problems to traveller cars is the habit of using it to locate the boom when you leave the boat. ie the boom hangs on the topping lift with main sheet tight.
This means that with every small wave the boat rocks and the car moves a little. Hence the wear.
I now drop the boom with sail down onto cabin roof where it does not move. olewill
bbg
2 May 2005
Harken (makers of McLube) advise against it. They make another product, "One Drop". Too much McLube on ball bearings and they will slide instead of roll, creating flat spots. One Drop will keep them rolling.
But I agree with others - first step is to wash and rinse thoroughly. Then apply some One Drop and re-evaluate.
