niccapotamus
Hi
our new to us boat is 30ft. It has a fully battened mainsail with the halyard coming back to the cockpit; it exits the base of the mast via a sheave, runs through a deck organiser and then to some jamming cleats before getting to the winch on the coachroof.
The sail is hard work to raise - I have to put my full (not inconsiderable) weight into raising it about 3/4 of the way using the winch for the last bit.
We have freed up the deck organiser which was seized.
I guess I have three questions:
1. Is it too much expecting the mainsail to be able to be raised by my wife (at least to the 3/4 point) before reaching for the winch handle?
2. I'm after ideas to make it easier - with specific product recommendations as I guess it will mean greasing the sail slides, and the blocks etc.
3. if some lubrication doesn't make enough difference is there much else than I can try other than swapping the deck organiser for a newer one? Would a thinner halyard significantly reduce the friction (for instance)
thanks!!
nick
thanks!!
nick
