Prospero
Active Member
I am about to install mains shore power on board and have purchased, inter alia, a shore power inlet fitted with a metal mounting and a Sterling Galvanic Isolator. On the shore power inlet is a sticker "Mounting not grounded, connect green (or bare) grounding wire." In house wiring one simply connects the casing to earth but I have been mulling over what to do for a marine installation. Logic suggests that since the mounting will only be live when connected to the mains supply it should be earthed before the Galvanic Isolator, but is my assumption correct? Any advice will be gratefully received. Many thanks.
<hr width=100% size=1>
