MAIB Reoprt on Hooligan V keel loss
CliveG
29 Oct 2001
Cambridge UK
The MAIB Have issued their report on the investigation of the keel failure, capsize, and loss of one crew member from the Max Fun 35 yacht Hooligan V 10 miles south of Prawle Point on 3 February 2007.
My fellow Ely Sailing Club member Jamie Butcher was killed in this incident.
It appears the the keel has been made by an inexperienced subcontractor who changed the design to save money.
The keel had an additional 160Kg added to it the year before the incident.
How many other yachts of this sort of design are there out there.
rallyveteran
30 Mar 2002
I think you missed this paragraph from the two page synopsis:
As a result of the MAIB investigation, the Max Fun 35 yacht keel has been redesigned and now exceeds the minimum required safety factor. New keels have been fitted to 7 out of the 9 remaining boats.
CliveG
29 Oct 2001
Cambridge UK
It is not the Max Fun 35 I was asking about but all the other yachts with this type of keel configuration.
I can't believe that these 9 boats are the only ones that have been compromise by cost cutting and subsequent design improvements.
tome
28 Mar 2002
kprick
www.google.co.uk
The keel design was altered to make the manufacturing easier by an inexperienced sub-contractor. However, the report shows that the original design was already flawed with a very marginal safety factor as a result of using ultimate tensile strength in the calculations
AngusMcDoon
20 Oct 2004
Up some Hebridean loch
Although the original design calculations were flawed, I think that is less significant than the fundamental design change the subcontractor made. At least the original design with the keel side plates running all the way to the top of the taperbox looks strong. The as-built design where the keel was just fillet welded to the taper box at the point of highest bending stress gives me the creeps - it was just asking to fail sooner or later.
I expect that design change was authorised by someone who had never been on a boat and had no idea of the loads boats are subjected to. Maybe he should be sent out into the North Sea on a Maxfun 35 in a Force 8 with 4m waves with one of his dodgy welded keels keeping him from a cold wet death to see if he still thinks it was a good idea.
kds
21 Nov 2002
Somerset
www.canongrange.co.uk
"I think that is less significant "
Perhaps you do - but the company that put the boat together should have made themselves aware of the change to the keel and the fact that they were already on the limits. What happened to quality control ?
Ken
wotayottie
1 Jul 2007
swansea
That applies to every boat ever built commercially. No manufacturer will build to the best possible quality standard without regard to cost - or at least wont do so and stay in business.
Am I the only one that feels uncomfortable when the MAIB talks about "likely cause of failure" and "possible hairline cracking". We know that the keel was inadequate - thats proven by its failure. Sounds to me like the MAIB report is to some degree speculation. Wonder how it will fare in court if it ever gets there.
savageseadog
19 Jun 2005
I think anyone commenting on this should be aware of there might be legal actions of various kinds either forthcoming or ongoing.
The one thing I will say without prejudice is that having seen many yacht keel roots is there are few that don't show some signs of rust and cracked filler ie at least some movement.
AngusMcDoon
20 Oct 2004
I totally agree - I was only commenting on the engineering aspect. The subcontractor should not have made the change, but neither should they have been allowed to get away with it. It seems that there have been 2 cockups, the technical one where the engineering was wrong, and a management/quality control one, where the technical one was allowed to slip through.
I vote with AngusMcDoon. These boats are marginal in all aspects but that keel fabrication has to be the worst mechanical alteration I have seen.
Going from a box with 4 longitudinal walls and 3 stiffening webs to a empty box with the stiffening not reaching, never mind welded to, the box base is a disaster.
Figure 11 shows that it broke the steel below the welds but above the shortened stiffening plates.
In light of the recent comments of trust in manufacturers about masts ...
The current world can not even make sure children's toys are safe.
marksaab
18 Sep 2006
London, Mersea
Leaving aside the obvious technical details. With various posts on this site about importing boats from the USA and the CE/RCD compliance required isnt it a bit staggering that this boat didnt have CE/RCD marking and that no COC could be supplied by the manufacturer! Also that this was not picked up by Trading Standards (I guess lack of resources) or the UK seller of the boat when it was new.
hairbox
10 Oct 2003
UK
Hi all
you lot make me laugh. when a keel falls off a BAVARIA and there is loss of life you slag the manufacturer off and make snide comments, now just listen to yourselves!!!!!!
cnh
18 Oct 2003
What interests me more is that it was designed as a RCD Category B.
Regs for this are:
B - Offshore; Wave height - Up to & including 4m; Beaufort - Up to & including 8
If you're racing a boat like that, then you may well find yourself in such conditions. Cruising is a different matter - racers press on at times when cruisers prudently retire to harbour.
Whislt I'm not convinced that some of the distinctions between the classes are terrribly meaningful, I certainly would hesitate before racing a Cat B boat hard.
Nicholas Hill
moondancer
8 Dec 2001
www.wisereach.co.uk
I am a big believer in the rule that good design looks right and bad design doesn't. Whenever I look at a very thin skeg keel and a heavy bulb it always gives me a shudder and I think about the loadings it has to take. To me they just do not look right.
DRANNIE
5 Sep 2005
Herts
I suspect unless the unfortunate crew member has dependants there will not be the financial incentive to bring legal action except perhaps by the owner for the loss of the boat.
I will be interested to see of there be a prosecution case brought for manslaughter.
Hairbox, I was in your words: "slag[ging] the manufacturer". Its like buying a car with no grease in the wheel hubs, you can not tell until the wheel breaks off. (Ref Volvo incidents) We rely on their integrity and gross errors, like these, sadly result in the loss of life.
I will continue hammering bad professional engineering and quality until more see how little we are getting for our money. As for Bavarias I would keep quiet after counting how many made it to the Fastnet. Very disappointing entry number and success rate. Or does it just reflect the crews of that type of craft only.
misterg
31 Oct 2003
N. Wales
I can only agree with tome-
Coming late to this, and having just read the report twice, I believe the design is more deeply flawed than the MAIB report suggests. Let me explain:
The marginal safety factor figures that the MAIB quotes come from the Wolfson Unit Report (annexe L) which creates a spurious figure of 357 MPa as the yield strength of the steel used. In actual fact, the yield strength for the steel used is specified by the standard and the manufacturer's data as 235 MPa (annexe F, and 1.11.2) - i.e. 34% less, so when safety factors of 1.38 are cited from the corrected analysis of the original design (section 2.4.2), that should be 0.91 i.e. the keel, as designed, will fail (through bending) at 10% below the load needed to simply hold the bulb out horizontally.
Whether the Wolfson unit made such a crude error, or whether there was a mis-match between what the MAIB thought they'd asked for, and what the got, I don't know, but the root of the problem is in the following paragraph from the Wolfson Unit report in annexe L:
The ABS Guide also states the yield strength is not to be taken as greater than 70% of the ultimate tensile strength of the material and not greater than 390 MPa where steel is used. The steel used in the design is quoted as having a maximum ultimate tensile strength of 510 MPa, therefore the ABS Guide value for the yield strength is 357 MPa and the allowable bending stress is 178.5 MPa.
This seems to be a howling "school-boy error" in interpreting the requirements of the ABS guide. What matters is the yield strength [sic] - where this might be unreasonably high (e.g. in high strength alloys), the ABS guide places further restrictions on the value that can be used, and it is these restrictions which have been re-interpreted into a fictitious stress limits.
The issue of the keel bolt fatigue failures (not relevant to this incident, but worrying, none the less) is not adequately addressed - their size satisfied the code, but still broke despite being made of a superior material (from the point of view of fatigue) than that specified.
Having read the report, my feelings go out to the family and friends of the lad that was killed. This incident should never have happened - IMHO (got to put that in) this is a failure of grossly inadequate design, compounded by 'on the fly' modification during production, the designer's lack of ability / opportunity / nouse to look critically at those modifications when he had the opportunity, and the company's acceptance of this.
It should also sound warnings as to whether the RCD will ever be an appropriate vehicle to control this sort of thing.
No connection to anyone or anything involved, just an erstwhile engineer with a bit of knowledge about metallurgy.
Andy
