Dieselboatman
‘Stick Mig and Dc tig’
Wasn’t that a 70’ S rock Band?
Sounds like it doesn't it! ?
I would personally buy a grp hull even if you buy a complete boat and cut away everything to end up with a bare hull.
That way you get a great hull that you know will perform with known capabilities.
Fitting it out is a task in itself and that can all be the newness you would like ?
Yeah may have to go that route....
28 ft Tiki wharram ,,, most boat per buck ,, and easy to build , flat pannel but with scope for a bit of " personalisation "
Bit big for trailer launching sadly!
If I could afford mooring costs, would love a 35ft steel pulled ex trawler or something!
AC machine is a wee bit expensive and argon not easy to get unless you have a company and account and that is high initial outlay
Yeah very expensive, did have one for a bit but had to sell due to wife getting pregnant!
Built several from sheet and what you propose is incorrect, begin with the structure and skin it afterwards as you can get the structure correct and massage it into shape if it is slightly out.
MIG better than TIG as it actually gives less heat and heat distortion, and heat distortion is the biggest problem; tack with MIG and sequence welding is the only way forwards.
Yeah done plenty of thin sheet rebuilds of vehicle cabs, flat beds etc, it's only I've seen quite a few use tig and on alu it's really needed
