Have you got an existing part to base one one, or the dimensions?Hi looking for someone who might copy a Volvo outdrive part which is obsolete ? Its the dog (or Shift Shoe in USA) from a Aquamatic 100B outdrive.
Similar to picture, around 50mm long.
SSG
I can borrow one.Have you got an existing part to base one one, or the dimensions?
SSG
Hi StephanSG,I’ve now got a lead on a factory part so this is now my plan B but I will definitely keep these numbers, thanks all
Thats very kind of you. I pulled that picture from google, as I couldnt find a picture of the one I need.Hi StephanSG,
I've just had the dog replaced on a Volvo Penta sail drive 120SE this summer, which looks remarkably like what you're showing.
Photos here are what I have ( the one removed ). It was purchased from a VP dealer who fitted the new parts so I can assume that VP still stock it.
Any help?
You are more than welcome to have the parts buckshee BUT they were removed along with the sliding sleeve as the gearbox only worked in reverse! so I cannot give any warranty as to how worn it will be.
Copious
and made from a casting.That part looks like its machined, hardened and then ground. Quite a lot of work.
