MissFitz
My Sonata is currently set up so that the kite halyard cleats off on the mast. I want to bring it back to the cockpit so need to remove the mast cleat.
Yesterday I went to do this and found that it is/was attached to the mast with machine screws and nuts, with the nuts on the outside. So when I take the nuts and cleat off, I’m left with two machine screws sticking out of the mast that I can’t pull out. One is loose and would easily push into the mast (which obviously I haven’t done). The other seems to be attached to something inside the mast, which does move but won’t allow the screw to be pushed in. The hole where the halyard emerges is just above the cleat but is too small to see inside or get a finger into.
I’m baffled as to a) how the screws (and whatever one of them is attached to) got in the mast in the first place, and b) how to get them out. Any suggestions?
