[2068]
Some are available on "the bay":
http://www.ebay.co.uk/itm/VOLVO-PEN...at_Parts_Accessories_Gear&hash=item3a465daac7
Oh Dear, that doesn't look good
Is that half of the casing with the threaded connections available as a spare part, maybe?
Or is there some way of welding / repairing?
ouch, that looks painful!
Clean up the casting removing all of the corroded area's, refit the inserts as shown and take to your local friendly fabrication/engineering company and weld the both together repairing damaged area at the same time!
If you don't have a local Co...Ship it down to me and I'll get one of our welding guru's to sort it for you.
Rob.
Gary , a mate who works at Fawley refinery gave me some of this stuff , http://www.belzona.co.uk/prod1k.aspx . to repair a casting on an old motorcycle engine (thread broke out of ali , similar situation ) . Have to say its the best two part chemical metal I`ve ever used . They use it as temp repair on certain pipe / fittings at the refinery to avoid long term shut downs . Might do as a temp repair until you can get hold of a reasonably priced ram . Good luck with it BTW .
thanks Rob but a colleague of the engineer who's removed it says it's aluminium and has said there's insufficient good metal to weld effectively. going to see if I can source a new part at a reasonable price and if so, I think that'll be the way to go for peace of mind... steering going at 20kts+ or in a marina doesn't sound like fun so better to spend in this area than skimp I reckon![]()
Good call David regarding checking these pipes, mine's worse than first thought
Looking like a new Steering Cylinder is needed
It is a bit odd - looks like the threaded section just fizzed away.
I checked mine today, and zero sign of any corrosion there on FP.
Could there have been a water drip, or an electrical bonding problem?
Gary
I have a aluminium braze repair material. Might work if you want to try some.
Ooof not cheap though G!.....but good luck with the refit, maybe wrpping the lot up in that greased waxy bandage stuff?..that I notice the commercial boys use on their net hauler connections may go some way in ensuring no repeat in a few years!
Good luck with this Gary. Have you got Tom lined up?
possibly Paul but I may end up refitting the new bits myself
Good man. As long as you have access it should not be too challenging, but I don't believe it is the easiest thing to get at? Still, after a Bimmer turbo, it should be a piece of cake![]()
