Gazza
Have just dismantled (for the first time) what appears to be a Lucas CAV type fuel filter on our Hunter Pilot. Unfortunately, there doesn't seem to be any filter element at all, with the fuel simply entering and leaving the bowl. It has a metal bowl with a separate collar/spacer about 4cm high on top, the two parts are then held onto the head by the usual central bolt.
I can't see that there's any room for a filter, as there is very little clearance under the assembly.
The thought has struck me that it could simply be acting as a water separator. Is this likely, or is there some specific (small)filter that would fit?
The top has Lucas KSS stamped on it if that means anything to anyone.
Help, please.
Help, please.
