saltyrob
Hi Folks,
The manual for our Volvo 2002 recommends API CD quality oil. I understand that this has been superceded by API CF4 quality.I have read somewhere that you can cause additional wear an older diesel engine by using higher quality oil,ie, CG grades. However looking at a container of Volvo's own brand,(expensive) marine diesel oil, it is CG4 grade with no reference to other grades. Shell Rimula is CF4 and CG4,Cl4 together with other standards.So is it correct that higher grades will cause significant additional wear and will an will an oil which meets CF4 as well as higher standards be ok.I am probable over complicating matters but its raining hard here in Suffolk, so have been reading too much.
Many Thanks
Rob
Many Thanks
Rob
