mlines
Having an American Boat with an American Workshop manual, everything in it is described using the American Manufacturers preferred supplier. Now I know that Quicksilver is available in the UK, but it seems to be in small and expensive quantities. Is there a more readily available "value" equivalent for:
Quicksilver Anit Corrosion Grease
Quicksilver Special Lubricant 101
Quicksilver 2-4-C Marine Lubricant with Teflon
Quicksilver U-Joint and Gimbal Bearing Grease
Quicksilver High Performance Gear Lubricant
Quicksilver Power Trim and Steering Fluid.
Quicksilver Synthetic Blend NMMA FC-W 4 cycle oil
Spray on Corrosion Guard
Martin
Martin
