ex-Gladys
<RANT MODE ON> Just installed a new one of these... with gimbals... What effing idiot designed this? The gimbal bracket is a bit of bent stainless, about a mm thick, and can only be used with round head screws/bolts. The pan holders on which the gimbals fit are bolted on with hex head bolts... Unfortunately, when you try then to drop the cooker onto the gimbal bracket, the bolt and screw heads conflict, so you have to tilt the cooker to fit it...
<RANT MODE OFF>
I feel better now...
<RANT MODE OFF>
