lw395
Under keel Clearance minimum safety margin 20% of draft is a common recommendation. For my boat at over 6ft draft or approximately 2m. 20% would be 40cm or 16 inches.
I'v a feeling I'd want at least twice that. Probably a meter would make me happier
Never heard that before.
sounds less than useful to me.
The issue is mostly the uncertainty in actual height of tide, uncertainty in charted depths, and an allowance for waves.
None of those are proportional to the draft of the boat.
The first two factors can be contained by using a local real time tide gauge and local knowledge.
The third is a matter of judgement, but you might hope that a wind that made the entrance a lee shore might make the water a little deeper....
The other issue is knowing that your track will be in the deepest water at the key time... can you trust the helm to keep the boat exactly on the transit etc?
I once motored very slowly into the Yealm, in a boat drawing 2.4m. The smaller boat 'following' me ran aground, I didn't.
At least nobody has mentioned the immutable rule of twelfths yet....
