Jokani
The usual method of fault-finding along a series circuit is called "halving"
With the CP switched on. the positive cable end to end had a voltage reading of 242mv. Using the halving method I found that the blade fuse from the battery switch to the fuse panel was a large part of the problem. I removed the fuse, and now the end to end voltage is 112mv.
These are the voltages with the fuse removed:
The CP is still receiving 0.2v less that the battery output (12.2v compared to 12.4v). Is this normal or do I need to do something else?
