neil_s
I have owned my Seal 28 with it's DV20 for nearly 24 years, now. When I got it, the engine ran well enough, but was obviously needing some attention. Lots of fuel leaks and a build up of yellow goo - emulsified oil - in the rocker box. After several years putting up with it, I took off the cylinder head and miked up the bores - within spec. I pulled out the pistons and found the compression rings well worn, so I replaced all the rings and also fitted new big end shells. I also found the oil way to the rocker box was blocked so fixed that too. Reassembled, the engine ran well, with no more goo in the rocker box. Over the years, I've also fixed the fuel leaks so all is well - except the oil pressure warning light comes on when the engine is idling. I accepted this, being used to old BMC cars! In my spares box I had a small pressure gauge from one of those Coventry Victor twin petrol engines so this year I decided to fit it to the DV20 to see what the actual oil pressure was. Bukh specify a minimum of 14 psi and a running range of 28 - 57 psi. I found that, when cold, my motor idles with a little less than 20 psi and runs somewhere between 30 and 40 psi. When hot, the idling pressure is about 5 psi and running pressure 20 psi. There is no knocking or other unwanted noises from the engine. In a way I wish I hadn't fitted the oil pressure gauge! Any ideas? The oil pump is easy to get at on the DV20 - would it be worth replacing it? I'm using Smith and Allen mixed fleet ultra 15W-40 oil. Would straight SAE30 (as specified by Bukh) help?
