Low Friction Rings, high load thimbles
For Clive (Coopec) as said I would raise the organiser gang up a little so that halyards arrive into the organiser at a manageable angle (in rising up to the organiser) then I would apply stainless steel sheet to the corner of the raised Cabin top section so halyards can run over the corner without damaging the GRP. Hopefully with only a small direction change. Thin stainless steel sheet can be found in a tape form with adhesive. it is a pity halyards exit at the mast base. As said much better to emerge from mast 2 metres from base. Still non reason to change now. ol'will
