snoozydude
Active Member
Howdy
I recently replaced my old PSS seal with a new one. It appears to be working fine however I have experienced a strange problem that I am not sure is related.
Occasionally after about 5mins of motoring there is a loud whining noise and the engine labors and will stop unless I take it out of gear.
When I take the elevator downstairs and check the PSS seal by burping it there seems to be good water flow getting through. I cannot feel any heat that might be associated with friction.
I was even suspecting that the graphite surface was sticking when it was wearing in but it should be well polished by now (about 20 hours running on the new seal).
Once this whining noise starts it will occcur shortly after putting the engine in forward in forward but not reverse. This will go on for about 30 minutes as I check all possible options then completly stop and away I go without an issue.
Had a thought it might be the alternator belt was too tight as that is exactly the sort of noise that is made but I would expect I would smell someting if there was that much friction on the belt. Have not had a chance to check the belt option but cannot think of any other options.
Gearbox oil is good and full and when I stop the engine and turn the shaft by hand I cannot feel any significant resistance.
Any help would be most appreciated.
