lots of steam
colhel
9 Jan 2011
Gillingham(Dorset) Boat Weymuff
I took the boat out on Saturday for a bit of a run after re-fitting the heat exchanger.
I'm not sure if the amount of steam coming from the exhaust (quite a lot) is normal bearing in mind the ambient temperature. I'm going to change the impellor and check the strainer as a matter of course and anything else within easy reach, but with temperature gauge not going above 90deg even WOT how concerned should I be? I'm aware the question "why's my exhaust steamy" is a bit like how long's a piece of string, but....
Cheers
I found mine to show more steam early season when the water is still cold and the spring air saturated. Whether or not you have a fault is another matter. Did you get a chance to look at any other boats out and if so did they not show the same?
What engines ? 90 is pretty hot. Volvos run in the low 80s
When you say Re fitted have you de calcified it ?
If I recall correctly 90 was within range on a boat we had with KAD42s and they used to run at around that. Last boat had Perkins and ran at 80-85, which was notably lower.
another thing to do is to check your manual and it will tell you how much water should be expelled at different revs, any less and its a restriction somewhere. I had this and it was a coating of fine gunge on the seawater strainer basket that wasn't really visible until removed and washed. Furthermore if it was 'lots of steam' as you quote that could be a placcy bag or something blocking part of your inlet scoop
Andy, I haven't checked the exhaust elbow, but will.
jrudge, She was antifouled last August but since November has been kept in Weymouth Marina quite close to sluse gate which when opened allows fresh water in, so even though the hull looks clean there could be tube worm on the shaft and prop which is difficult to check.
Thanks Mike, I'll check the strainer again and the inlet scoop.
Cheers
good call on the exhaust elbow too. worth taking it off and have a look at the stainless insert next to the turbo for pin holes.
check the temperature of the thermostat housing with an IR thermometer too. My temp gauges over read by @ 6 degrees.
Cheers
Had I not experienced it myself I would not have believed the difference. It was the first trip of the season and off we go to Ibiza. Temps pretty high. Full consumption Hi. Boat speed - low.
Scrape the props off and had as much of a go on the bottom as a tank of air would let me. Transformed.
Well aware you will slow down, aware you will use more fuel ( but not as much as I actually did). Didn't know temps would rocket. I do now.
Are you on outdrives? I had an issue with steam on my last boat and it turned out to be a burst exhaust bellow. It was replaced and the same thing happened again. Turned out the engineer I was using at the time was using non Volvo parts and it just wasn’t up to the job. Got the proper VP part and no problems after.
This is what I found when I checked our old boats turbos, an easy clean and improved water flow and reduced steam .
That’s nothing....
Before
y4mUSzThXQ1Vj7_jyBgfTmqpyxgOEZNbf0nBrjW9rhcFGH6aKZLoJQ8BaWUytYOGcaH_knMyQQ_g3d5-NRdMgHD4dS87eAGl8voMTAn4I8eFLWESMZM0zuVjlFFMTzC-K8Pp5yqxR2RWyz-EZ2hWrzoHO-1LmhjdtZ3vEed1HGC6M8RpHBvjzo3dKDDUH2Q7fJFVVPtnQ9lIVRi69216_XMVg
New
y4m_K7g1UD1mRRJANn0ddKUOT4Wtiy8c_MDidIisFbLtj8HfAO_cGme_sp2t2Vq9UjMbYPWZAaUBJdcwvbpnHjh21_7Pj1Dm_Fy8kkNIc8nY32wrvaYo3FQKk9x7C2MRmmSQ2Fmr_ZsEKOJ2JOXuirt8tVe0BlslzJT3X26KM02_T_LHQxi-Ixk95_w0-Ks-HDvkwaimK8dLgko3ysyuV0Sug
Ours is shaft drive. Looking at the schematic for the tamd41 A, I'm slightly reluctant to start taking the exhaust elbow off until due to the exhaust flap, I haven't had a good prod around yet but I'd be worried about damaging something. It's a very restricted working area too which doesn't help.
