lost anchor - b****r
kashurst
10 Oct 2003
Spain
this will make you laugh/cry - lost anchor off the bows today. left home marina with anchor, arrived at destination no anchor - I even looked in the anchor locker!!!!. shackle had come undone sodding bolt was just sat there by the roller. make sure you check your shackle bolts
Did you not mouse the shackle?
Count yourself lucky that it didn't happen with the anchor deployed, it could have then been the boat that went missing!
how do you "mouse the shackle" thanks.
Mousing is where you put wire through the hole at the end of the pin and then through the body of the shackle to prevent it from coming undone. Many people also use a cable tie to achieve the same result. Should be done with any shackle which is subject to any load, such as anchoring or mooring.
Take a look at boats around you and most will have their anchor shackles moused.
Sorry you lost your anchor, bet it won't happen to you again!!
older and wiser and a tad poorer - monel wire - I'll get some cheers all, as you say at least boat wasn't anchored a the time.
