nigelmercier
RIP
- Joined
- 20 Jun 2007
- Messages
- 16,234
- Location
- Live in Kent, boat in Canary Islands
A few weeks ago I noticed a loss of revs at WOT. Thinking there was something wrong with the propeller, I was pleased to find a plastic bag wrapped around it; however, the next day I still had the problem.
Although this is a new propeller, I'm 99% certain that it is the same specification as the old one, and 100% certain that I've had full revs with the previous one, which was indeed slightly larger than the original. The blades are clean. The propeller turns freely by hand, and when under sail.
Symptoms: the last 1/3 of the throttle does nothing when the engine is under load. In neutral, it revs up to 4000 (then I chicken out).
Here is an extract from my log book:
Engine, lack of power at WOT: Rev counter reading about 15% low, max revs under load on quay therefore 1,700 RPM (2000 RPM displayed). Both fuel filters replaced, pick-up pipes blown through (some grit found), return pipe checked for air bubbles, fuel tap blown through (small piece of black plastic removed, possibly from a 10 litre tank), air inlet cleaned, exhaust elbow removed and de-coked, exhaust pipe cleaned with cloth pull-through, each injector disconnected in turn: same loss of max revs (about 500) in each case. Final test run with direct fuel line to lift pump, no different. However, a sea-trial showed that maximum revs now displayed 2500 RPM into a head wind.
A diver at the marina has suggested that there could still be some plastic jammed on the sail-drive shaft, and that it only makes contact when the propeller is driving the boat, thus pushing the propeller towards the sail-drive. There is a 5mm gap between the propeller and the anode.
I therefore open this poll: is this a likely solution?
