Chuckle54
I have a VP 2002 in my GK29. A week or so ago we left the mooring and within a few yards the overheat alarm sounded. Limped back to the mooring and discovered that the coolant from the sealed circuit seemed to have gone. There was no trace of coolant in the bilge. Refilled and so far the problem hasn't re-occurred and the engine runs as smoothly as ever.
From research on the internet it seems the issue could have been caused by a cracked head/faulty head gasket or corroded heat exchanger? The oil level is constant and clean so possibly not a cracked head or gasket?
Which leaves the heat exchanger. I've been advised that the internals of the exchanger could be corroded and allowing coolant to mix with the raw water and then be expelled from the exhaust.
I had a good stare at the heat exchanger and noticed white deposits on the body and around the rear rubber cap. I've ordered new gaskets and will attempt to replace everything.
If the internals are corroded could I get away with covering the brass tubes with silicon tubing of the correct diameter. A bit of a bodge I know but the price of a replacement heat exchanger is ludricous. Also wondering why it hasn't reoccurred. We were recently motoring into a 36 knot head wind against the tide and the engine behaved impeccably with no loss of coolant whatsoever.
