Plevier
My Lopolight bi-colour has failed. It appears to be an internal fracture of the cable just where it leaves the unit, if you bend it in one direction you can consistently make the light work. I think it's very poor that the cable has no strain relief sleeve where it exits the casing.
I'm trying a warranty claim but it is a bit outside the 5 years. If they won't help, I'm wondering if I can grind the epoxy encapsulation away very carefully and expose the connection points, I'm guessing the wire is soldered to pins.
I wondered if anyone had tried this or at least if anyone knows the layout inside the epoxy and whether there is a chance without hitting the PCB that must be in there?
If I have to replace it, it certainly won't be a Lopo. Anyone got recommendations for a reasonably priced LED unit? I wondered about the Osculati ones. ASAP sell some of their models
http://www.asap-supplies.com/lighti...ation-light-bicolour-red-green-12v-24v-731875
http://www.asap-supplies.com/lighti...avigation-light-bicolour-red-green-12v-731895
or this is a 2 mile one that looks as though it should be more conspicuous (it's a 10.5m boat so I could use a 1 mile unit but would prefer to be more visible)
http://www.piplers.co.uk/brands/osc...avigation-led-lights-for-vessels-20m-s-s-case
