Jcorstorphine
I am looking for some advice on selecting the best waterproof adhesive to bond 2 mm thick GRP to Aluminium.
I don't want an adhesive which is an immediate bond as the GRP section are 1.4 m x 0.3 M and I will need a few moments to correctly position them. I would also like the adhesive to be easy to spread so that it will even out with a small amount of pressure as the panels are quite big.
I am looking at using wood battens and G clamps to provide some compressive force but I need to be sure I don't deform the GRP panels as they are only 2 mm thick. I will be able to use some CS stainless screws in places to make sure it does not fall off and I will have a temporary batten at the bottom of the existing section to take the weight and provide a fixed vertical position.
The above is to bond GRP panels I have purchased to cover the existing lower aluminium panels on my motorhome which have become corroded in places.
