richardm47
The problem with deep cockpit lockers is that the contents spread out messily over the floor, and the vertical space isn't fully used. Mine contains 3 fuel cans that don't stack on top of each other. I need to replace them. And get back some of the floor area they use. So I googled them.
I found this £30 metal can that the seller says will stack several high. But there is nothing to hold them laterally, so not ideal.
I found this £19 plastic can, they could probably be made to stack in a small frame. But it's only 1.5 litres, not really big enough, again not ideal. And expensive!
I'm also thinking about adapting these £7 HPDE plastic cans, by adding a home-made moulding underneath each can. The moulding would be shaped to fit the top of the can below. And to sit flat on the floor. But what can I make the moulding out of? It must stick to that plastic stuff.
Any thoughts? Other ideas?
