sailaboutvic
We have used the handle and it seems to work ok , so I guess there no problem there ,I might question who you bought from
This is 30 years ago - We had a new yacht and a little later had a problem with the folding prop. Cannot recall what it was now. I contacted the Gori, who asked for the prop number, which I gave them. They replied and said it was not unexpected, whatever the problem was, as the prop was 6 years old, the yacht was newish - the dealer, selling us the yacht had swapped the prop on their yacht for the new one on mine.
Our little windlass is an RC8/6. 1,000 watt motor with maxim lift of 600kg and a retrieval speed of 32m/min - its incredibly fast. Our chain is 6mm 0.8/m and anchor 8kg.
I know its not easy - on ours downright difficult - but you have a manual lift using a standard winch handle?
If you have a gearbox issue I'd expect the gearbox to be at least warm.
Have you thought of running the motor disconnected from the gear box? though not sure what it would tell you. and/or using the winch handle to manually lift - see if its unnecessarily hard (so something wrong with the shaft or gearbox).
Jonathan
I just done what paul suggested , run the windlass without the chain it's not blown the trip after two mins but the motor started to get hot through the casing .
Add weight to that and I wonder if that heat would be a lot more .
