tugboat
I need to remove my windlass (vertical shaft) to allow some nearby welding. I have removed the drum and gypsy, and now I'm faced with the clutch cone. I've got the key out of the shaft keyway and the clutch cone now spins on the shaft but will not lift off. It almost feels like it has a ball bearing within it which has stuck to the shaft. However - there is no reason for there to be a bearing as the clutch cone is normally keyed to the shaft. The diagram shows a bearing below the cone but I think it is located in the deck plate where the shaft emerges from below. I'm reluctant to use a puller on it without someone reassuring me that is the correct thing to do. The shaft is clean, no gunge, however worth mentioning that the ally drum casting is broken where it fits on the shaft so the unit may have been strained/overloaded at some time. Would be glad of your thoughts/advice, or words of wisdom from anyone who has stripped one down before. Thanks.
