Stemar
On Jazzcat, we have a door with a yale lock to go indoors (it isn't below on a Catalac!) and a sliding hatch maybe 1m 20 wide that slides around a metre. Currently, it's locked closed with a small bolt fitted to the saloon roof at the forward end, which is awkward to use and less than totally secure.
I've thought about a bolt on the inside of the aft bulkhead, but those I've seen that aren't too intrusive don't go up far enough, as there's a gap of about 10mm filled with a rubber seal, so the bolt would only bear on the rubber. My other idea is an oversized version of this,
but made of wood, which would be big enough to bear against the whole of the height of the vertical bit of the hatch.
Any suggestions for a better way? I'm not looking for total security, as a determined thief will get in no matter what I do, but I do want sufficient to keep a casual thief out
Sorry if it's difficult to visualise - I tried to make a diagram, but my CAD skills just aren't up to it!
